I'm basically new to DVD creating but felt it was time to get all those Godzilla and Larry Boy tapes on disc. I'm using an ADVC 100 (which by the way is everything you fiine folks here said it is) to bring in my movie to an .avi file. I've already created a couple DVD's which play good and seem to be pretty good quality but on one of these movies which is around 2 hours in length I had to cut the avg. bitrate down to 3000 in order to get the whole movie on disc. I've read that if I use another source to encode the audio instead of letting TMPEnc do both the audio and video I can use a higher bitrate for the video by means of using ac3 audio versus PCM. I've tried to use Goldwave but when I load the .avi file it just sits there and times out. Thank you for any help offered.
If the previous post wasn't long enough I forgot to mention what is happening to me with Goldwave. I launch Goldwave and open my .avi file. It gives me a "Deflashing To Disk" info box. After approx 5 minutes it shows the left and right channels but no audio in them. Then naturally when I try to save as it gives me "File gives a length of 0 for audio data or audio data is missing! Sound cannot be read" info box.
Thank You for any help. -
Do I need to load anything else such as a codec onto my system for this to work.
Calling MediaInfo from Visual Basic to et video info
By SearchQuality in forum ProgrammingReplies: 18Last Post: 2nd Nov 2011, 06:36 -
Need basic info on Simple profiles when capturing video with XviD codec
By snafubaby in forum Capturing and VCRReplies: 1Last Post: 19th Mar 2011, 21:54 -
Research info needed
By vbthedog in forum Newbie / General discussionsReplies: 0Last Post: 7th Jan 2011, 21:45 -
karaoke info needed
By pabcsn in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2008, 06:37 -
Subtitle woes..explanation of basic principles needed
By dADDo in forum Newbie / General discussionsReplies: 18Last Post: 9th Nov 2007, 01:55
