After a lot of browsing on this forum, I think I have an idea as to how I will convert/capture analog video. I plan to use a DVcam with analog to digital conversion with passthrough. My computer has firewire ports, so I will only need software capture (or store) capatilities on my computer. Is this correct? Could there potentially be audio/video synchronization problems using a DVcam to do the conversion? Thanks.
John VB
Rather than use your DV Cam as a passthru, I would first record your analog to the DV Cam tape. This will digitize and also lay down a steady TBC. Then, I would transfer the tape to your computer. This is a suggestion made to me by a Sony rep. An extra step but the up side is that now you have a digital copy that you don't have to store on your hard drive.
Best (hopefully free!) software to capture analog video?
By The Big Cheese in forum Capturing and VCRReplies: 3Last Post: 7th Sep 2011, 21:52 -
Analog Video Capture Hauppauge 1600
By jrtmouse in forum Capturing and VCRReplies: 6Last Post: 13th Aug 2010, 15:46 -
Analog Video Capture - Which of the following methods is best?
By nharikrishna in forum Capturing and VCRReplies: 4Last Post: 30th Mar 2010, 23:46 -
Capture analog video from sony camcorder
By gthoman in forum Capturing and VCRReplies: 14Last Post: 14th Apr 2009, 15:32 -
Analog video capture in Vista.
By Frogged in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2007, 10:47
