I have been testing how much my CD-R's can go over the 700 MB threshhold, and have been surprised that they far surpass that threshhold when burning MPEG (already up to 763). This is great, because I can up the bitrate,etc, but what accounts for this? I am using TDK 80 minute, 700MB CD-Rs, and the normal variation of megabytes for other burning is at most 3 MBs. Is the real megabyte limit larger when burning MPEG, or can a VCD program use some type of algorith to compress the information even more? Thanks for any comments.
mpeg video is written in mode 2 on the cd with less error checking. That is why you can fit approx 800mb on an 80 minute cd but only 700mb for data (including avi video).
The idea is that the DVD/VCD player will skip over the bad video info (if there is some) and keep playing and not stall on the bad video data, it just skips over it.There's not much to do but then I can't do much anyway.
Standalone DVR's with HDD's - how much can they REALLY hold?
By m3 in forum DVD & Blu-ray RecordersReplies: 32Last Post: 26th Jun 2011, 15:54 -
it may be smart of hold off on sandy bridge...
By deadrats in forum ComputerReplies: 2Last Post: 12th Feb 2011, 22:04 -
Which format produces better quality overall MPEG-2, MPEG-4 or .x264?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2009, 03:00 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
what size of the movie a dvd can hold?
By volam in forum Authoring (DVD)Replies: 13Last Post: 27th Mar 2008, 16:37
