hi, i downloaded a movie that along the way i guess had soem corrupted area. anyways i was using edonkey and it said that any corrupted areas would automatically redownload. i would assume it did that becuase the original posted file size was 800 meg, now sitting in my incoming folder is a 1meg file. i was hoping that when i started up nero (ver 5.10.15) it would load the cue sheet fine and create the movie. but as it turns out i get an message saying that the 'medium i am using is not suffient' i'm not sure what to do now. i'm assuming the file is correct but to large to burn direct. i am using 700meg cd's. Is there a way to correct the file size, split it, turn it into a different format so its still usuaable, etc i really don't know what to do. Any help would be very much appreciated!
thanks
D
Try reading the file with winrar or isobuster. If you can read it then you should be able to extract the data from the bin file.
There's not much to do but then I can't do much anyway.
Authoring oversized DVD, then shrink to fit on a disc?
By adamberkey in forum Authoring (DVD)Replies: 1Last Post: 28th Apr 2012, 00:39 -
Large corrupted AVI file, what to do?!
By WaveofShadow in forum Software PlayingReplies: 12Last Post: 14th Sep 2010, 00:42 -
DVD file too large to burn to disc..how can I make it fit?
By Natalie88 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2010, 09:14 -
.dv file too large to fit on FAT32 formatted hard drive - not sure of next step
By CBlanchard in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2010, 00:25 -
Oversized video file...
By Felo in forum Video ConversionReplies: 3Last Post: 18th Jan 2008, 03:14
