i got some movies (mpeg) with chines subtitles is there any way to remove it? thanks for any help.
good question i'd like to know if theres an answer myself he he
kinda new to this he he -
Define movie? Do you mean a DVD with selectable subtitles. Or a DivX file with the subtitles encoded into the file? I suspect you are referring to the latter. In which case the short answer is no. Those are not subtitles, they are images that have been encoded into the video file, you might as well ask:
'The are these trees in the video I have, is there anyway to remove them.'
With that said, you can try a filter like VDubs logoaway. Some people have had good results with this filter, but IMHO you really can not selectively remove pieces of a video without leaving some artifact. -
i mean a div x file . and i try logoaway filter in v.dub and that worked thanks for the tip.
How do I remove unwanted text in movie
By rocks911 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Oct 2011, 11:35 -
Remove black lines from movie
By pensioner in forum Newbie / General discussionsReplies: 5Last Post: 12th Jun 2011, 08:39 -
How to remove subtext from movie
By striker9 in forum Authoring (DVD)Replies: 4Last Post: 12th Aug 2010, 05:06 -
How can I remove ads from my video cd movie
By nusratjaveid in forum EditingReplies: 21Last Post: 10th Jun 2010, 17:14 -
Movie maker -- remove audio ?
By mister in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 6th Jun 2009, 13:48
