i hope someone can help me with this cos its doing my head in.
ok i use tmpgenc to encode my mpegs
either ripped dvds or captures thru my digicamcorder.
ive done it loads of times with success but recently every time i use tmpgenc i get between 50 & 75% thru and my pc turns off![]()
i mean my monitor goes off, lights on pc tower stay on but with no response but when i turn off at mains let it cool down it comes back on ok & i try again with same result.
now it doesnt turn off every time just most of the time.
ive used differnet versions of tmpgenc
probs started on v 011.26.110
then updated to 25.88.44.152 worked fine with no problems
that demo ran out so now using
tmpgenc plus 2.5 & its done 2 short mpegs & shut down on 2 as well
ive change the memory & also formatted but problems still keep arising
any ideas anyone
cheers
It could be that your CPU is overheating? Check on your system BIOS if it is set to shutdown automatically on a certain CPU temperature. My P3 600Mhz used to sound a warning bell halfway through encoding with TMPGEnc. I raised the threshold temperature for the alarm and haven't heard it since (well, maybe because now I use the 2.4 Ghz
TMPGEnc seems to use CPU very heavily. -
Any encoder uses the CPU intensively.
You've likely got a hardware problem either CPU, ram or power supply. Try swapping out parts if possible to isolate the problem."Art is making something out of nothing and selling it." - Frank Zappa
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 12:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 15:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 18:56
