yes, i have found a way.
not directly relevant to everyone, but interesting nonetheless. compressing an AVI thats completely black or white gives above a 99% compression when zipped in winzip. try it. i experimented, and seemed to get an average compression ratio for 720X576 video of about 55%, useful if you need AVI's on your drive, but dont have space for them. also, anyone running drivespace or double space, will experience AVI's being about half their original size. maybe next gen storage devices will hold zipped 24bit AVI files.
				Results 1 to 11 of 11
	Well of course! The whole idea of zip type compression schemes is to remove redundancy. So sure, if you have a 100% white or 100% black video you'll get huge compression. Now please them me why you think anyone cares.
	well, like i said, it's useful if you're captruing uncompressed AVI's, but need a bit of extra space on your HDD. i was only trying stimulate discussion.
	As as point of interest, using RAR with "multimedia compression" achieves much better compression ratio for images or video than ZIP.
 Regards.
 Michael Tam
 w: Morsels of Evidence
	This thread is pretty useless... y?
 This method is absurd... I'll quote a text from a friend...
 Same thing happens with Video and Images... A blank image will use low space because it's only a lot of bits repeating...That has to do with something called information theory and the "entropy". The entropy of the fast and evil is the "measure of disorder" or randomness in a data set.
 Compressors usually work searching files or sets of symbols symbols to be repeated within a file to replace those symbols by "codes" equivalent. The decompression process does not, replace these codes by blocks representing and thus able to obtain the original file.
 A text file where most characters are equally likely to appear can be compressed enough. A video file that has many almost random data is very difficult to compress.
 An example. If I had a file that contains 1024 letters "A". Then to compress it might say "A repeat 1024".
 Normal file:
 Compressed file:Code:AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
 Code:Repeat "A" 1024
	"Automatically Close Old Threads After X Days"
 http://www.google.com/search?complete=0&hl=en&source=hp&q=%22Automatically+Close+Old+T...e+Search&gbv=2
 Of course, Baldrick may think it's not worth implementing
	I have a feeling this has been discussed before but a simple message showing the original thread start date with a note about grave digging if it's more than a year old should suffice. I'd hate see the option completely taken away unless it's connected to post count and/or signup date . IMO, it's best to let the mods deal with the few that get by and aren't relevant.
 Anyway I feel bad bumping this any further.There's not much to do but then I can't do much anyway.
  Deinterlacing MiniDV AVI file and saving as lossless AVIBy Dave2ic in forum Video ConversionReplies: 3Last Post: 27th Dec 2010, 16:11
  Most Efficient Play on Netbook: DVD or AVI?By chinook9 in forum Newbie / General discussionsReplies: 5Last Post: 20th Mar 2010, 13:33
  Are there no good lossless video compression algos?By CursedLemon in forum Video ConversionReplies: 21Last Post: 13th Oct 2009, 12:18
  Lossless Video Compression for Movie MakingBy Sparehead01 in forum Video ConversionReplies: 4Last Post: 6th May 2009, 19:43
  AVI - Lossless TrimmingBy tripecac in forum EditingReplies: 14Last Post: 4th Jul 2008, 03:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
