    May 2002
    MONTREAL - CANADA
    I am NEW on this typic . Wich software or method to DVD backup .
  2. This is a question asked by billions of newbies each day. Define "best". You are going to have alot of people who will recommend this and that with their personal preference. If you did a search and read up, you can learn what the good and bad experiences others have. But sadly, at the end, what may be best for someone may not be the best for you as you don't have the same eyes and setup like them. You didn't even go into details on how you want your DVD backed up. DVD?SVCD?VCD?DivX?etc....
    If you need to know what I use then I'll say I use DVD95Copy. All this post does is lead to flame wars. That's why a lot of forums make it a rule to not say what's best because you'll have a millions of different opinions.
  3. I use a combo of IFOEdit and DVD2one. take 30 minutes
    When the movie is too long, or I easyly see compression problem on my computer monitor, I use IFOEdit and Instant Copy 7. take 3 hours
  4. Check out my topic: https://www.videohelp.com/forum/viewtopic.php?t=157343
    This is just an idea, but it could be a good start. It depends on your config and on what you want to do (full disk, movie only, etc.)
