Got a movie today but can`t get no picture,,,,sound is great but just a black screen,,,,got all the latest codecs but never had this problem before.
Everything in Gspot is ok apart from Stream type & A/V Interleave
Its says TYPE OpenDML AVI : I/L Not supported. IMRR n.s.![]()
Any idea`s please would be a great help![]()
Results 1 to 10 of 10
Uninstall ALL your codecs! make sure GSpot says everything is missing 8)
Then, install ONLY what I tell you:
Kristal Studio Codec Pack v4.33
DivX v5.0.5 Video Bundle
XviD Video Codec
Then try opening your Movie again
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
As above but make sure that you do not install the nimo codec pack, more bother than it is worth.
I'll defenetly agree on that one! Nimo is a Big No No! nothing but trouble!
Best Regards,
Sefy Levy,
Cheers,,,,, got it working on me PC now but when I`ve converted it to mpeg to play on dvd player there`s no sound
Lets deal with it a problem at a time, did you test to see if there is sound when you play it back on the PC ? 8)
Then, how did you convert it, and what settings did you use for the Audio ?
Best Regards,
Sefy Levy,
it played ok on PC,,,encoded it with TMPGEnc,,,,,tried a different audio codec,,,working fine now
Thanks anyway -
Glad to hear that the problem is atleast solved 8)
Best Regards,
Sefy Levy,
yes, It's called a format, but I won't tell you to do that
Basicly most Codecs come with an installation pack, uninstall and reboot after each package, then make sure no AVI is playing anymore, also go to the Multimedia and check any codecs and try using the REMOVE on them.Email me for faster replies!
Best Regards,
Sefy Levy,
VCR Playback Problem
By Robert the Bruce in forum Newbie / General discussionsReplies: 9Last Post: 27th Jul 2011, 08:05 -
playback problem
By winston879 in forum Software PlayingReplies: 2Last Post: 14th Mar 2011, 15:33 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
Color Playback Problem?
By magikalfly in forum Video ConversionReplies: 7Last Post: 19th Feb 2009, 00:14 -
playback problem
By stigslim in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Aug 2007, 18:19
