Hi all,
I've been using DVD Maestro for my DVD authoring ie I use TMPFEnc to generate the *.m2v files and use seperate ac3/wav files for audio.It's a nice easy to use program BUT the movie review only appear to work with a hardware DVD card fitted..so the question is are there any other more modern authoring programs that can use separate video and audio sources (inc ac3) and will also give a preview of the finished DVD?
Hope this is not too dumb a question
Cheers
Ody![]()
TMPGEnc DVD Author just came out might wanna give the trial a try...
http://www.pegasys-inc.com/e_main.htmlJustin
:agree: -
This might interest you still beta but looks promising. I am not sure if it has ac3 support you can check it out.
Dd
DVD Lab
http://www.mediachance.com/dvdlab/Main site
<password removed at request of program author>
rDownload from forum
http://www.mmbforums.com/cgi-bin/forums/ikonboard.cgi?s=7926873e2341f905c858dd5f344221...=ST;f=28;t=245(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
you could also just install cinemaster to get preview with maestro -- its on your install cd ..
you dont need the hardware decoder -
Install any DVD software player based on the ravsent player, like Matrox's DVD Player you can buy it from matrox web site for like 8bucks. It will enable the play function. Also if you have an ati vid card most of the dvdsowftware that comes with ati cards is based on it and will enable it. It uses some dll's or something you may find just the dll's somewhere.
+Sean
edited by tgpoWe all like Sheep have gone astray... -
Thanks for all the replies - I got a copy of cinemaster and installed that to get DVD Maestro preview function
dvd recorder with hard drive alternative(s)
By monks19 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Sep 2010, 17:24 -
Alternative to DVD Lab Pro
By 557953 in forum Authoring (DVD)Replies: 7Last Post: 4th Jul 2010, 11:17 -
software alternative to nero to put a dvd on my HW
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2010, 07:36 -
DVD Shrink Alternative
By BNA84 in forum Authoring (DVD)Replies: 6Last Post: 22nd Feb 2010, 18:51 -
MoxiBox alternative - DVD recording problems
By oprquestion in forum DVD & Blu-ray RecordersReplies: 1Last Post: 10th Aug 2007, 10:08
