I am converting some analog home videos to DVD. I've experimented and have decided that I get acceptable quality by capturing to AVI with VDub with PicVideo MJPEG, converting to MPEG-2 with TMPGEnc and authoring with Ulead DVD MF2.
I understand that once I have the MPEG-2, it is a non-no to edit the video because it will decompress the video back to AVI then compress back to MPEG, resulting in quality loss.
My question is, does this apply to adding chapter points to the MPEG-2 in DVD MF2? Does adding chapter points in the authoring software require the decompress/recompress process?
Bowlpacker,
As long as your mpeg2 files are DVD compliant, it will not re-encode them by adding chapter points. Make sure you enable "do not encode mpeg compliant files" in the setup portion of the program.
BTW, I use Studio 8 to edit and encode to mpeg2, import to DMF2 and add chapter points with no problems.
Good luck,
Dave
PS Triming/shortening a mpeg file is considered editing.
Add chapters (at least) to already made DVD
By tge101 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 13:16 -
What is the best way to cut up an Xvid file or add chapters to it?
By Chrushev in forum Newbie / General discussionsReplies: 2Last Post: 29th Mar 2010, 05:14 -
How to add Chapters, Subtitles and convert for itunes?
By TC1006 in forum Blu-ray RippingReplies: 1Last Post: 14th Jan 2009, 10:31 -
Need to add chapters to a 3GP file
By fredsp in forum Video ConversionReplies: 4Last Post: 22nd May 2008, 03:22
