How?![]()
surcode DTS encoder or the dts encoder from DTS -- though you would have to conver the DTS stream to wav or aiff files first .. in which you would lose qualiy - better to leave on dvd in the first place ..
@wizzy
may be you want to burn a CDR from DVD soundtrack.
beware: it does not work without decoding/downsampling/encoding.
if you attempt to burn a CDR with 48Khz DTS sound, it wont
be played a the right speed.
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 14:36 -
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 17:25 -
How can I make a .dts from wav's ?
By Robertus in forum AudioReplies: 2Last Post: 5th Jul 2010, 16:20 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 13:10 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 08:06
