Hi, I'm getting a DVD writer fitted on Monday, and I'd like more info on the freeware DVDShrink.
When you rip the DVD, do the menus still function? or is it better to just rip the movie and leave the menus, extras etc out?
Cheers.
I leave the menus out and do the main movie and sometimes add things at the end of the movie , such if it has a video or something. if its a layer 1 just use the dvd decrypter to do 1 for copying. if its layer 2 just use dvdshrink to do the main movie. you will not lose any quality either I use it everyday. plus when I put in my dvd player I dont have to hit any buttons it just plays and starts on its own
But if I decided to keep the menus, would they function properly?
you need to make a full cd copy and keep all the extraOriginally Posted by Papa Lazarou
or you take IFOEdit, rip all the extra you don't want, make a FUll copy with DVD2one (or DVDShrink) then you have what you want !
if you remove extra before compressing, you will have a "movie only + menu" copy since all extra are at 0meg
dvdshrink
By Faerel in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2010, 23:07 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 17:17 -
Which is better - shrinking with DVDShrink or......
By robertazimmerman in forum DVD RippingReplies: 21Last Post: 4th Feb 2008, 13:12 -
What does DVDShrink reduce?
By moviebuff2 in forum Newbie / General discussionsReplies: 25Last Post: 30th Nov 2007, 03:02
