My problem is this: I have tried several times to convert some AVI files I have to MPG so I can play them on my DVD player.
I have done it sucessfully however the movie is always too tall/wide (I know this because the movie has subtitles).
The setting I used is:
NTSC 4:3 525 lines
non-interlaced
Full Screen: (keep aspect ratio)
Does anyone have any ideas as to why the movie keeps turning out too big on my TV?
I'll give more details if necessary. Thank you.
Basically what I'm looking for are the right settings for the TMPGEncoder to create a VCD that will display at the proper size on my TV.
The default settings given in the html guide on this site is the setting I am using and is incorrect. Thanks again for your help.
<font size=-1>[ This Message was edited by: RayGamer on 2001-09-18 21:13:49 ]</font>
It depends on the aspect ratio of your original video. If it is wide screen, then in TMPGEnc (the Advanced tab), make sure you select the source video aspect ratio to 16:9 instead of NTSC 4:3 525 lines.
And watch out for the interlace setting too. Again, this depends on your source video !!!
ktnwin - PATIENCE -
Thanks for the reply ktnwin. ^_^ Well, Something of a minor success for me today, I was able to make it work by changing the aspect ratio to 16:9. I can't believe I overlooked that.
Well, now I need to figure out how to reduce the wideness of the video while maintaining the tallness... hmm... if anyone eles has any ideas please let me know, but don't sweat it too much because I should figure it out eventually.
By the way, nice quote ktnwin. ^_^ Thanks again. -
Glad that it works for you.
That's what this great site is about.
ktnwin - PATIENCE
DVDAuthor incorrect ratio after conversion
By davelakers in forum Authoring (DVD)Replies: 17Last Post: 12th Feb 2012, 16:35 -
TMPGenc Authoring 4: problem with incorrect bitrate
By bpchia in forum Authoring (DVD)Replies: 5Last Post: 3rd Aug 2011, 01:53 -
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 19:08 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:44 -
PAL DVD to NTSC Conversion (read as much as I could)
By DW in forum Video ConversionReplies: 3Last Post: 27th May 2008, 02:42
