  1. Hi,
    I have ripped two dvd'swith dvd decrypter to my HD.
    They are both DVD-5 so they don't need any re-encoding etc...
    Now if I want to burn the files Nero gives me the following error.
    DVD-Video compliance test failed.
    I have burned many dvd's already and I don't understand what is wrong with this dvd. When I take a look at the files they are correct and everything is copied correctly. Unfortunaly I don't have the dvd anymore so I can't choose a different ripper. Anybody around here who has a clue what is worng. Otherwise I have to rebuild the dvd again and that is a bitch to do because it's a chineese movie so I need subs.
    Thanks,
    DVDGEK
  2. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    are there any 0kb files?
    you could always try Get VTS in Ifoedit to fix it
    sometimes Nero whinges even though the DVD is fine
    how fussy is your standakone DVD player
    do u not have a RW to try it?
    backup the original IFO's 1st of course b4 doin owt
  3. Hi,
    The problem is solved with DVDshrink.
    I have lost the menu but I don't care much about that.
    Everything is still on the dvd so I 'm happy that it worked
    Thanks for the advise,
    DVDGEK
