This may seem simple but I have only used PCM before. (which works perfectly)
I have some AVI's that I have either encoded or re-encoded, and they have PCM audio.
However, to get them to work with my Qcast software, the audio needs to be either MP3 or AC3.
I'd like to get MP3 to work, but when I convert with Vdub it's out of sync, then slowly fades back into sync, then back out, etc....
I am just copying the video directly and using the Lame MP3 codec. I have already scanned the AVI for bad frames.
Any ideas?
Actually, I think I've figured it out. Under Video> Frame Rate, I set the rate of video and audio to match. Seems to have worked.
I will post if I need any more help -
Ok, After doing some testing, I'm still having a problem.
Now it starts out in sync and gradually gets more and more out of sync. -
Figured it out, I ripped the audio out with Vdub and converted separately, since Vdub was apparently making it variable bitrate instead of contstant.
Oh, and -=Neo=-?
I point to the dictionary. Or perhaps a program with spellcheck? Hmmm?
Sync problems after merging mkv video with mp3 audio
By billman1234 in forum Video ConversionReplies: 5Last Post: 29th Jun 2010, 16:00 -
Audio out of sync after converting AC3 to MP3 in AVI with VD
By huykin in forum AudioReplies: 6Last Post: 1st Oct 2009, 14:27 -
Movie's audio out of sync after converting WMA to MP3
By Talayero in forum AudioReplies: 11Last Post: 25th Sep 2009, 05:39 -
Teen falls in open manhole while texting
By freebird73717 in forum Off topicReplies: 19Last Post: 13th Sep 2009, 18:44 -
Removing Niagara Falls background noise
By MedievalMan in forum AudioReplies: 4Last Post: 28th Sep 2007, 20:21
