  1. When I encode a video with CCE, CCE made a logo inside the video! How to remove it or wich version don't have it? At last... How to make a svcd instead of a DVD?
  2. Member steptoe's Avatar
    You will get the logo, as I assume you are using the trial version, which it states in the demo you will get a logo on your final output
    If you want rid of the logo, either buy it or another cheaper encoder or use a freeware converter
    After having used/got fed up with CCE SP, look at some of the cheapware or freeware utils, TMPGenc and VirtualDub/NanDub/VirtualDubMod spring to mind, and there is a lot of support for all of them
    TMPGenc Plus is well supported, but does tend to be slow when compared to a dedicated encoder like CCE SP, so if you are in a hurry to convert files, do what I do, and run it overnight
  3. Buy the cce basic for $58. It is fast and does a great job. With an encoder available at this price and with this quality, there really is no point to spending hours trying to find working versions of other programs. I have used sp (trial version) and with all things being equal, the finished quality is no better than basic, although it does have options available that most of us do not know how to use or have no interest in learning.
    I cannot tell the difference between my dv tape and the completed mpeg 2. I encoded a 46 minute video with music in 74 mins.
