  1. hello how can i convert divx vcd svcd, ect to mpeg2,
    tried some of the how to converts and they do work but size of the file at the end is very big .ie if i convert using tmpgenc it asks at the end what size to convert to but the minimum it will allow is about 48% of the disc, and if you are only converting a small file to start,about 200mb. is there another way to convert to mpeg2 and still keep files small.
    i dont mind if they are about 700mb at finnish.
  2. Member Conquest10's Avatar
    Chicago, IL
    well, how long is the file? because if you're trying to fit 3 hours into 700 MB, then you have to try kvcd or something.
    His name was MackemX
