When converting from avi to mpg, TPMPEG says " floating point error" and then stops.
What does that mean?
Can it be fixed?
not sure what it means but it happened to me so i had to load the avi into bbmpg and cut the avi at the very next frame after the illegal decimal then load that portion into tempge then continue converting then i joined them back together minus the bad frame then i cut it to fit on cdr. maybe theres an easier way but it worked for me
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 11:42 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 09:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 08:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 02:22 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 17:47
