  1. Guest
    I'm having problems buring SVCD. I've used many different ways of buring as suggested in this forum and on the guides.
    When I burn both NTSC & PAL SVCDs on the same CD it seems that either the NTSC plays fine and the PAL ones don't or vice versa.
    Therefore can both be burnt on the same CD or do they both have to on seperate CDs, one for NTSC & one for PAL?
    May 2001
    London, UK - Bonn, Germany
    Authoring/Burning programs ask you before adding your files if you want NTSC or PAL standards. I think the logical conclusion would be you'll need 2 disks.
  3. You can burn both NTSC and PAL tracks on the same S/VCD. For example, the demo VCD has both PAL and NTSC tracks...
    Of course, whether or not your player can understand the change in format is another issue.
    Regards.
    Michael Tam
    w: Morsels of Evidence
