I have an avi which I want to convert to VCD
when I go thru the infor on this site it says look at the frame rate and size to determin which option to use on the converter.
Well it gives the sizes and frames rates of the 2 US ones and PAL
BUT I have the frame rate of PAL and the size of the US format.
so do I use PAL or not?
will the size difference chop off some stuff?
can I change the frame rate in something to the I get the size and frame rate of the US one?
Madhombre, if you're in PAL land (difficult to tell as you haven't set your location in your profile) then keep to 25fps and change the frame size. as tx suggests, TMPGenc will do this nicely, is free, and easy to use. if you're in NTSC land you'll probably be better of converting to an NTSC frame rate, as USA equipment has poor PAL compatibility.
Multi-System VCRs; PAL N tape, PAL VCR
By darito in forum Capturing and VCRReplies: 14Last Post: 17th Apr 2012, 12:54 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 14:47
