Hi Guys !
I just wanna know what it's the difference of DVD+R and DVD-R. How can i decide wich one i choose ?
Thank you very much !
hgtvg.
From this site.
DVD-R and DVD-RW
DVD-R/W was the first DVD recording format released that was compatible with standalone DVD Players.
DVD-R is a non-rewriteable format and it is compatible with about 89% of all DVD Players and DVD-ROMs.
DVD-RW is a rewriteable format and it is compatible with about 72% of all DVD Players and DVD-ROMs.
DVD-R/W supports single side 4.7 GB* DVDs(called DVD-5) and double side 9.4 GB* DVDs(called DVD-10).
These formats are supported by DVDForum.
DVD+R and DVD+RW
DVD+R/W has some better features than DVD-R/W such as lossless linking and both CAV and CLV writing.
DVD+R is a non-rewritable format and it is compatible with about 83% of all DVD Players and DVD-ROMs.
DVD+RW is a rewritable format and is compatible with about 72% of all DVD Players and DVD-ROMs.
DVD+R/W supports single side 4.7 GB* DVDs(called DVD-5) and double side 9.4 GB* DVDs(called DVD-10).
These formats are supported by the DVD+RW Alliance. -
Read this post:
https://www.videohelp.com/forum/viewtopic.php?t=152616
Scan down and find my name.
Full-page comparisons on DVD+R vs. DVD-RI'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
Bob W:
Very good Non-judgemental statement of the facts!
Just a few additional things to clarify though...
DVD+R/W's "benefit" of Lossless linking is of no use when doing a DVD-Video title that is burned as DAO. It really only helps with multi-session data burns--that's where the "linking" comes into play. Supposedly, DVD-R/Ws can now also support Lossless linking with DATA, but that may be just marketing of futureware (firmware).
Similarly, the benefit of CAV writing only comes into play with writing Data File backups, as DVD-Video titles MUST be written as CLV.
Also, the DVD-Rs you mention really seem to refer to DVD-R(General). DVD-R(Authoring) supports 3.95GB and 4.7GB single-sided discs, but NOT double-sided discs (yet). Also, the 3.95 discs are compatible with ~93% of players.
Scott -
txpharaoh:
I agree with most of what you said in that other post, but must take exception with your labelling of Sony as crap.
This is the way I see it: Sony has at least 3 divisions: Broadcast/Pro Electronics, Consumer Electronics, and Software/Media. The Pro group is rock-solid, probably the best-engineered stuff on the planet! The CE group is split between Hi-end/Prosumer and Lo-end/Bargain. The Hi-end stuff is quite good--Flimsy parts sometimes, but good design. The Low end stuff is driven by the whims of the software/media side, and is usually CRAP.
Sorry, I know it's a little OT from this thread, but I just couldn't let that go this time (I was tempted to reply on the original thread but was too busy).
Anyway...
Commerical DVD v/s DV->DVD quality difference ?
By Movie-Maker in forum Newbie / General discussionsReplies: 6Last Post: 16th Aug 2008, 15:21 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 21:06 -
The difference between mpeg-2 and mpeg2-dvd in Premiere and the use in DVD
By umforrest in forum Video ConversionReplies: 5Last Post: 16th Jan 2008, 21:36 -
Can anyone actually TELL the difference between Blu-ray/HD-DVD over DVD?
By corvette77 in forum DVD & Blu-ray PlayersReplies: 62Last Post: 1st Dec 2007, 15:37 -
What is the difference between a cd/dvd duplicator and cd/dvd burner
By wan2no in forum Newbie / General discussionsReplies: 7Last Post: 5th Nov 2007, 21:12
