My motion menu (13sec clip) only loops once then goes on to play whatever button is selected. How do I make it to keep looping until I activate one of the buttons?
Sounds little strange to me. The controls for looping, as you are probably aware, are located at the bottom of the menu editor (I'm assuming you're not using it in the 'compact' view). It's odd that it's only looping once. Usually, I'd expect it to be all or nothing, unless you were doing SPRM programming etc.
Arky ;o) -
Arky is right, the controlls are on the bottom there. You need to tick the loop box. What its doing is an option so the wrong one must be selected.
SeanWe all like Sheep have gone astray... -
Thanks for the replies... same thread I opened at doom9 and decided to just continue that one.
http://forum.doom9.org/showthread.php?s=&postid=310485#post310485
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
Motion menu thumbs in DVD Workshop 2
By milway in forum Authoring (DVD)Replies: 7Last Post: 3rd May 2008, 08:12 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 13:03 -
Editing Motion DVD Menu
By gallardo in forum Authoring (DVD)Replies: 5Last Post: 6th Nov 2007, 22:12
