    Sep 2001
    The Netherlands
    What tool do you suggest to convert the DivX avi movies I downloaded to (S)VCD compatible audio.
    5.1 MPEG audio seems to be TOO damn complicated... ;-(
    thanx,
    La Torcia
  2. tmpgenc j with the toolame plugin is one possibility
  3. Goodluck finding a DVD player that would play 5.1 audio mpeg stream from an SVCD anyways. Otherwise you could just mux the AC3 stream with the MPEG-2 video file if you're player supports Mini-DVD.
