I've got a DVD-R that I want to copy for a friend. He says his player will only play NTSC DVDs. I have no idea if the DVD I have is NTSC or PAL. It plays just fine on my DVD player (Apex 1500 which I looked up and it will play both). He suggested some tools to use to determine if it is NTSC or PAL, however they are for PeeCees and I don't seem to find anything similar for Macs. I've tried the Mac DVD Player, VLC, and Quicktime (which won't open anything, of course).
Any suggestions and what software to use?
Lynne
pop the DVDr in your mac, then start-up OSEx, click on the "Vid" button and it will tell you if it's PAL or NTSC...
hope that helps. -
sorry, I forgot to mention, if you don't have OSEx, use Macupdate to locate it..
I tried using that. It bombs everytime - or rather it 'uexpectedly quits'.
If I start OSEx before putting in the DVD, it bombs as soon as the DVD mounts. If I start OSEx after the DVD has already mounted, it quits right away. I do have the latest version of it also.
I just updated to 10.2.6, so I don't know if that is the problem or what.
Can VCL software convert NTSC to PAL?
By bobvideo in forum Newbie / General discussionsReplies: 5Last Post: 7th Nov 2011, 13:37 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Software Recommendations for converting 1080p HD clips to SD NTSC or PAL?
By seville63 in forum Video ConversionReplies: 2Last Post: 27th Mar 2010, 10:04 -
Need software that identifies PAL/NTSC
By djkilla in forum Software PlayingReplies: 5Last Post: 20th Jul 2008, 20:03 -
PAL->NTSC ripper software?
By coody in forum DVD RippingReplies: 4Last Post: 9th Oct 2007, 00:50
