  1. can someone help me with some ? i have on making some templates for TMPGEnc my DVD player only plays vcd so i have made some svcd size vcd templates for what i encode what i wont to know is what is the best way to go with bitrate ?cbr vbr 2pass stuff like that time is not that big a dill
    allso can i make templates for MainConcept and panasonic MPEG1 encoder?
    TIA rich
  2. Member SaSi's Avatar
    Jan 2003
    Hellas
    To begin your encodings, you don't have to invent your own templates. Tmpgenc comes with pre-defined VCD templates. Make a test with them and use the ones that fit you best. Also, Tmpgenc has a wizzard that will help you do the same thing without a template.
    For a VCD, you can't have VBR. Only CBR. Many DVD players will happily play the VBR videos, however it's not a bet for yours.
    The more I learn, the more I come to realize how little it is I know.
