i downloaded a video in 2 parts preset for vcd....i had a dvd-r so id much rather put it on a dvdr but all i got was 2 sets of BIN and CUE files how do i change em back to MPG
VCDGear. BIN/CUE to DAT/MPG is what it does. Alternately, ISOBUSTER will do it (any BIN/CUE, not just movies).
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
ok can you give step by step instructions?
I downloaded reloaded and have 2 bin and 2 cue files.
convert to mpeg, vcd -
all the mentioned programs do it. They also have help files to assist you,
nero is also just as good, select the "burn image option" then in the file types it select bins and cue, select the cue and click nect job done
oh and i have the very same film, burnt and its a cam job, not the best but watchable -
You could even read this:
https://www.videohelp.com/forum/userguides/141726.php#vcdbin
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
