I have tried a number of tools and have not found what I am looking for (or maybe I don't know all the features available in each). I am trying to find a single tool that will copy a DVD to 2 DVD+R disks or at the very least split them so I can burn with Nero. I generally use DVD Decrypter to rip it to my hard drive, but I looked at IC7, DVD95Copy, DVDXCopy, DVD2One, Maestro, etc and I have not found an easy way to simply perform a FULL DISK copy. One some disks, I have used IFO Edit to split and re-add the features/extras, but I usually always have problems with the second disk (illegal navigation issues). I have search all of the forums and have seen the posts about using Get VTS Sectors and changing the Pre Command, but no luck.
Could someone provide either a good tool to use or help with the IFO edit problem.
[I apoligize that I am crossing threads with these 2 questions...]
Thanks in advance.
You don't have to rip your DVD if you're using DVDXCopy. Normally DVDXCopy will split your DVD-9 onto 2 DVD-Rs...What didn't work?
From what I read (I admit I have not tried it yet), DVDXCopy will not copy all of the features, menus, etc (i.e. full disk copy). Am I wrong (I hope so!)
Thanks -
DVDXCopy will make a perfect backup on 2 DVD-Rs, keeping all menus and extras. Check that link:
http://www.dvdxcopy.com/faq_answers.htm#12DXC
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
how to copy from DVD recorder to external disk or blue-ray writer?
By uwacm@gmx.de in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2011, 05:14 -
Vista 32 bit ... Disk full? but only 35GB files on a 108 GB c:\ partition.
By edDV in forum ComputerReplies: 6Last Post: 6th Jul 2010, 02:55 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Dummy VOB, full disk extraction...cannot be done
By sknox in forum MacReplies: 11Last Post: 9th Oct 2007, 21:36
