is there any simple way to remove L or R track? audio in vcd?
The reason i ask, because, if i put those mpeg file to the VCD > DVD, (put 4 or 5 vcd on 1 DVD) it seems the dvd player cannot pick the right channel to play, and anyway i only need 1 language.
Can anyone help? thanks
NO kidding ..
doing the same thing .. but i can't find any easy way of doing it other than to extract as Wave,
use wave editor to delete the R track,
copy the L track onto the R track.
Yep, 900+MB per movie, and very painful.
OH yes, then MUX wav back into .MPG.
If anyone find any easier way to do this PLEASE let me know!
Thx!
-Kor
BATCH remove audio track from mkv
By MarquisdeOz in forum AudioReplies: 53Last Post: 30th Jul 2018, 09:48 -
How do i remove an audio track from an AVI file?
By alih786 in forum AudioReplies: 51Last Post: 29th Nov 2016, 07:31 -
How to remove audio track?
By MAAG in forum AudioReplies: 13Last Post: 13th Jun 2012, 19:19 -
how can i remove wind noise from a audio track
By suomiaussie in forum AudioReplies: 2Last Post: 23rd Mar 2008, 10:10 -
Eliminate a VCD Audio Track
By andyt415 in forum Authoring (VCD/SVCD)Replies: 10Last Post: 3rd Jun 2007, 02:01
