Helo can someybody help me with dvd-ripping.
when i ripp a pal dvd 20fps to pal video-cd 25fps
the motion gets jerkey (when i ripp dvd ntsc 23.9fps
to video-cd ntsc film the motion is ok).
thanks.
well ntsc film is 23.975 fps, so it is exactly the same fps.
but is there such thing as 20fps pal? -
Yes there is such thing as a pal 20 fps pal dvd (i have 3 of them on my harddrive now).
I had the same problem...
There was only a problem with DVD2AVI, I had the option "Force Film" checked, when you use "no frame ..." (it's the first option in ths menue), you get the usual 25fps film an can encode it correct.
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 14:36 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 13:47 -
How to fix a divx made at 20FPS
By Talayero in forum Video ConversionReplies: 4Last Post: 4th Jun 2007, 09:25
