Hello,
In PICVideo MJPEG, in Subsampling, what's the difference between 1/1/1, 4/2/2 and 4/1/1? Which is best for high quality capture?
Also, what is the meaning of Luminance Quality and Chrominance Quality? What settings are best for high quality capture?
Take care
Hello
Originally Posted by W_Eagle
Click on 'help' and then click the setting you require further information on.
I've been doing extensive testing recently, in fact I captured the same one minute clip 12 times using Virtualdub and different PICVideo settings and these are the optimal settings for me.
Quality 19/20 is not noticably different than 20/20 but produces around a third of the file size.
Good luck, if you use these settings then I've just saved you hours of work/testing, I hope it's of some use
I was capturing anologue from a VHS-C camcorder buy the way but intend to use the same settings for VHS capture.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Hello Pal,
Thanks a lot.
Originally Posted by Silky31
Why don't you use "Codec Enabled?
Take care -
Anything for an easy capture, eh?
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
Convert 4:3 PICVideo mjpeg to 16:9 DV w/o losing clarity
By brassplyer in forum EditingReplies: 12Last Post: 5th Jan 2011, 01:13 -
Questions about format and settings
By joeplaysguitar in forum Newbie / General discussionsReplies: 0Last Post: 4th Jun 2010, 17:36 -
New to ffmpegX A few questions about settings ect!!
By HELLZWINDSTAFF in forum ffmpegX general discussionReplies: 5Last Post: 1st Jul 2009, 23:54 -
ac3 filter settings questions
By THX-UltraII in forum AudioReplies: 0Last Post: 11th Feb 2009, 05:32
