    Feb 2003
    Philadelphia, PA
    Does the region encoding carry over when you back up dvds? If so, is there a way to make the dvd region free?
    May 2001
    It depends how you do it. Just create a DVD title set, then run IFOEdit on all the .IFOs and make them region free. I don't use any of the "one-step" crap, so I am ignorant as to their treatment of the region bits.
    Feb 2003
    Philadelphia, PA
    How do I go about this? I'm a n00b..
    Apr 2003
    Maryland
    Just some info about dupes or backups. I use several programs but whenever I make a backup with DVD Shrink, I can take the resulting copy and I can stick it in a standalone player and copy it directly with my standalone DVD recorder and copy it 1:1 with not Macrovision refusal or visual/audio problems in the resulting 2nd copy. If I try it with the original, the recorder will not even accept to begin to copy it. It will display that the original disk is copy protected. SO I can only assume that DVD Shrink is disabling the initial macrovision protection.
    Any thoughts?
    No DVD can withstand the power of DVDShrink along with AnyDVD!
    Dec 2002
    Macrovision can't be used on a DVDR. It can be used on an 'Authoring DVDR'. It's flagged on a part of the disk you can't write to.
    Region settings are usually stripped away with just about any DVD Ripper program.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
    May 2001
    Not true, ol' Gaz-man. CSS is what can't be added (on either GENERAL or AUTHORING disks), because the area where it is supposed to be is pre-embossed.
    Macrovision is just a flag setting (because the DVD player does all the "protectin'" stuff), and can be added by all high-end authoring programs. However, you need a license and a "per unit" fee to legally use the flag.
