If I have more than 1 audio stream how can i set wich one isthe default?
What are you authoring DVD, or SVCD, and what proggie are you authoring with? Need more info dude.
SeanWe all like Sheep have gone astray... -
Authoring DVD,
I'm new and I don't have a fixed authoring tool I'm open to any sugestion.
thanks -
Well, not alot of inexpensive authoring apps support multiple audio streams. In fact I cannot think of one, infact most consumer level software requires you video to be a system stream, that is muxed containing both audio, and video so you get no choice. If you use a pro app like Scenarist or Maestro it varries but in Maestro you just drop the audio into the 1st track and thats it, you would have to set a rule using the commands to make it play a differant one as default as Maestro always uses track 1 as primary audio stream unless a rule is written.
Set default audio device in VLC from 5.1 to Stereo?
By Xenogear900 in forum Software PlayingReplies: 3Last Post: 28th May 2011, 03:43 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
fails to set default audio device using Windows Media Encoder
By George2 in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 00:12 -
TMPGEnc AW 4: default audio stream for different tracks
By reini in forum Authoring (DVD)Replies: 2Last Post: 3rd Apr 2009, 14:33 -
How can I set the default audio stream of a .VOB file?
By knn in forum EditingReplies: 9Last Post: 19th Jan 2009, 19:10
