and keep it AC3 Audio Track?
you can use virtualdub, www.dvdrhelp.com/virtualdubaudio (skip the part where you convert it to wav). After you demultiplexed it with virtualdub it is best to fix the ac3-headers with ac3fix.
extract a matrice from an xvid avi file ? [SOLVED]
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 15th Nov 2011, 09:14 -
Extract from avi file and add to existing mkv file
By pathumx in forum MacReplies: 6Last Post: 8th Apr 2010, 18:57 -
Extract the second soundtrack from avi file
By SB4 in forum AudioReplies: 4Last Post: 4th Mar 2010, 11:44 -
How to extract an AVI clip from a ts video file?
By alegator in forum Video ConversionReplies: 5Last Post: 10th Mar 2008, 19:48 -
Extract sound from AVI video and convert to AC3
By blizzery in forum AudioReplies: 2Last Post: 25th Jul 2007, 14:06
