is there a way to know what i should set the max & min birates to, when using 2pass vbr. i used the calc to figure out what the average should be. i am making an xvcd.
actually, i think what i should be asking is: should i encode in constant bitrate at my dvd player's peak bitrate or use vbr?
If your DVD player's peak bitrate is the average bitrate you calculated, encode CBR.
Else use VBR and set max to the max(-30kbits or something) your dvd player can handle and the min to 0.
I just got done encoding a movie with 2 pass VBR, the settings were 4500 max 2500 avg. and 1150 min. and the movie looks like crap to me it is a XSVCD. The avi. I used was very close to DVD quality I couldn't tell the differents between them. I would say use CBR I think it looks better but if you are trying to save space use the VBR.
You say your AVI was DVD quaility but was it a ripped DVD or a DivX file? Did you set motion search to high (the default is fastest IIRC)? Do you turn detect scence changes off? Can your DVD player support 4500kbit/s?! Go above the max bitrate and 'odd stuff' starts happening (skips, pauses, dithering, etc).
If 2500kbit/s is your DVD max, then just use CBR.
Aside - I make DVD rips -> xSVCD w/ CCE 3pass VBR min=900, ave=1600~2000, max=2500 all the time and they are DVD quaility encodes (2-3 discs thou
I didn't make the .avi(Divx) myself but it looks perfect. My DVD player can handle 4500kbits/s it usually looks great with CBR but I used VBR this time to fit it on 3 cds. I didn't play it on my DVD player yet but it looks like crap on my computer. I didn't turn detect scence change off I left it on. I use 4500kbit/s as often as posible. I also used 3:2 pull down and non-interlaced, the movie is NTSC Film. I put the motion search to highest quality. Am I doing something wrong?
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 16:59 -
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Xvid Setting: 1pass Quantizer vs Bitrate Mode, vs 2pass => Quality
By carlaron in forum Video ConversionReplies: 12Last Post: 4th Oct 2010, 08:12 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
10 min max file for YouTube
By DirtBikeMike in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2010, 08:59
