    Mar 2003
    Tacoma,WA
    I am trying to backup only the last 4 chapters of a DVD.
    I am using DVD2SVCD.
    I Rip using internal routines I load the ifo file and choose the last 4 chapters of the DVD in the "Movie Length" section of the Coversion tab.
    I hit "GO" then everything works great till I get an "ERROR" screen.
    I says it can't open the "Title Picture.bmp.als" with an error number.
    How do I handle this.
    Thanks Brad
    Mar 2003
    Tacoma,WA
    More info. on my problem.
    I downloaded a trial version of CCE.I have been using a registered version of TMPGEnc.
    I got a little more info. on my error.
    It said:
    AVI File open-AVISynth_Script_.according to registry.
    The type of file specified in AVIFileOpen does not have a handler to open it .
    Im really stuck.
    Brad
  3. If you only want a few chapters use Eazy Vcd from tools. Once it has completed use tmpgenc's merge and cut feature to issolate the video that you want.
    If it's wet, drink it
    My DVD Collection
    Mar 2003
    Tacoma,WA
    So.
    Do you think its only a problem of just trying to backup a few chapters?
