Hi,
I was wondering what are some good editing programs that will get rid of silent spots, remove words, for example is there is a .mp3 that has a bad word how would I get rid of the bad word with the .mp3 still good quality, and also increase volume, and do all of this at the same bitrate? Please and thank you.
Ghtpua, you might want to check out Cool Edit Pro or Cool Edit 2000 from Syntrillium Software. I've been using CE2000 for a while now and I love it.
http://www.syntrillium.com -
For some of those things the software will pretty much have to decompress the MP3 to modify the audio and then recompress, so there will always be some loss of quality. If you use a program with a good MP3 compressor the quality loss will be minimal, though.
If you use Audacity (http://audacity.sourceforge.net/) you can use LAME to handle the MP3 compression. Audacity and lame are both free, so it won't cost you anything to try it. -
Use MP3Gain to adjust volume(better than normalize)
http://www.webattack.com/get/mp3gain.shtml
and Audacity to edit and merge.
I need an EASY program to edit things out of .flv files
By J Tinsby in forum Video ConversionReplies: 6Last Post: 28th Jun 2011, 03:07 -
Free program to convert my cd's to mp3's?
By scustalow in forum AudioReplies: 15Last Post: 18th May 2011, 07:26 -
Is there such a program which can split up this 1 .mp3 into single songs
By natty in forum Newbie / General discussionsReplies: 6Last Post: 8th Apr 2009, 21:35 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 07:06 -
mp3 editing with VirtualDub
By tomchook in forum AudioReplies: 2Last Post: 2nd Jul 2008, 11:48
