plz can someone help me i want to take a xvid. avi movie that i got from the internet into SVCD to watch it with best quality in my dvd player, to see in my tv!! but i dont know what programs i need!! plz can u tell me what programs i need and how to use them and set them up to take the xvid to svcd!! the best settings n quality !! and step by step on how to do it??? i tries to use LSX mpeg encoder, but first an error message came up sayin the audio was unsupported, then when i press to encode the movie, it said that the encoding perimetters did not match svcd format, and then it said encoder failed to decompress avi video stream: possible reason, cannot find approraite codec!!! so plz tell me what to do and what program to use!!
Results 1 to 17 of 17
?? TMpgenc and vcdeasy!! with other programs such lsx mpeg encoder or cinemacraft encoder sp????or is tmpgenc that fastest and greatest quality to do it??? PLz tell me what programs are the best and fastest for near dvd quality???isn't there a better n faster way to do it -
Will VCD easy automatically perform the header trick?
Thanks in advance,
VCThis is so much fun! -
PLZ help me! HERE are 2 movies that are XVId, avi, that i want to convert to SVCD so i can watch clearly, and best picture quality to my dvd player on my TV!! I used G-spot to get this information! The 1st movie is DRumline(its 700 mb)for video format its aspec is 576 x 240 (2.400 : 1)
the bitrate is 689 kb/s the framerate is 23.976 FPS and the duration is 01h 58m 19s codec is 4cc: XVID the video codec is XviD MPEG-4 Video Decoder: Not this is for Audio: audio codec is MPEG Layer-3 Decoder-->Morgan Stream Switcher, the adudio format name is 0x0055(MP3) ID'd as MPEG-1 Layer 3, n the audio bitrate is 130 kb/s (65/ch x 2 ch) VBR LAME3.92, with FS as 48000 Hz: NOw it said everything is installed and no errors and i can watch the movie!! NOw when i go on tmpgenc or any other program that you tell i should use for better and faster quality!!, plz can u tell me what settings to change.. for ex. on lsx mpge encoder u can change tha framerate!! so what should i change it to, or do i chnage it so it can match everything from the g-spot info??ANd should the profile to load be NTSC which has a frameraet of 29 or should i use pal whicjh has a framerate of 25<< SO please gv eme the correct settings to change!! or in TMPGENC<what should the best settings i should you for best great quality, and or best speed! if it has to be slow for great quality, i undesrtand i just want like dvd quality to convert it to svcd to watch on my dvd player. PLZ HELP ME!! thank you for ur replies -
Try dowloading and installing the ffdshow codec. It has allowed me to see Xvid's clearly. You get it at the left in the tools section.
Goodluck,
plz that info u gave me does not help me!! i need to know what seetings to use on tmpgenc for the xvid, .avi movie i got from kazaa to convert it to svcd to watch on my dvd player
You do not change settings at first when you use TMPGEnc. Launch TMPGEnc, close the wizard if it opens. Load your video, select the name of your output file, select the Load button at the bottom of the screen. This broings up a list of templates. Select the SVCD template ("SuperVideoCD(NTSC).mcf", or "SuperVideoCD(PAL).mcf"), then select Start. Change no settings here, unless the video turns wrong.
I know this seems a little frustrating at first, but while you are encoding your video read the newbie guides, and since you are converting video, read also the conversion guide here.Hello. -
thanxz for the lil advice, but do i load the ("SuperVideoCD(NTSC).mcf", or "SuperVideoCD(PAL).mcf,!! or can i choose 1 of them????? rememember the movie framerate for my movie i want to convert is framerate is 23.976 FPS ((so do i load the ntsc or pal??????? plz tell me
Use the SuperVideoCD(NTSCFILM) template. This is assuming that you live in a region 1 location. If you are in the U.K. then use the PAL format. According to one of the moderators (Adam) TMPG will do an internal 3:2 pulldown which is needed to play on your DVD player (again assuming you live in a region 1 location.)
ok thanxz but me.......... those settings were good, but there are other settingds on tMPGenc that u can change for best picture quality n sound so u can watch on my Tv!!!!!!!! plz can u tell me those best setttings to change and do?????????????????????????????????? for the moviei i posted up!! i just want it to be the best picture quality!!!! Now i
have LSX MPEG ENCODER< (they say thats the best codec to convert to SVCD< because its the fastest n best picture) but when i tried to use it it does not convert XVID's,i also got CINEMACRAFT ENcoder SP!but thats no use,!! i heard thats the best to! PLZ CAN ANYBODY TELL ME WHATS THE BEST xvid ENCODER TO CONVERT TO SVCD!! N TELL ME HOW TO USE THE PROGRAM, OR JUST GIVE ME THE NAMe!????????????? I REALLY NEED YOUR HELP, come on i thought theyre were experts out there! or is THE TMPGENC THE ONLY XVID ENCODER ????????COME ON PROFESSIOANLS Help me -
Jeez man, sounds like you need calm down some.
Learning to convert to svcd takes a lot of time and experimentation. Even with all of the experts out here, you just have to do some work yourself. It took me between three to six months to understand enough about the process to do a good job.
Suggestion: If you are in that much of a hurry and it is a huge emergency just go to Blockbuster and rent the stupid thing.
BTW, talking about how to copy movies that you do not own and giving their names is not allowed on this board. It is illegal
thanxz but em!! i checked all ova the internet(google search) and they said the best encoder is lsx mpeg encoder, but i tried it with a xvid movie, and it cant proceess< plz tell me then how to setup it up fro the best settings on TMPGENC!!! what settings did u use 4 ur xvid movie~!! plz tell me !! i need all the help i can get!!! if u can tell me \step by step what to do !!! thank yo u
well putOriginally Posted by stevendm
enice177, LSX and CCE are going to take you quite a while to get the hang of, and I doubt anyone here is going to be persuaded by your ranting to write a 'guide for dummies' for them just for you.
Use the templates in TMPGEnc (which make things very easy for you). If your source is an Xvid from the web, the difference between the settings (and the different encoders for that matter) is not going to be that noticeable, as the source is so highly compressed in the first place. -
enice
follow the link and read, If I write it down for you or you look in the guides that have already covered this your still gonna have to read it.
Most XviDs are 23.976fps you can try making a SVCD at this frame rate but coffee coasters is all you'll get. Most modern Standalone DVD players will read 25fps PAL and 24fps NTSC. Your PC DVD drive wont care what the frame rate is it has plenty of resources to correct this but standalone players have very defined bounderies based upon standards.
You need to read the XviD to SVCD guide you may also want to read the converting the frame rate guide.
There is not one program that will load the file make the file and burn the file without any prior knowledge except the Nero Plugin but its crap.
Making Mpeg2 video takes time in itself and plenty of reading so you need to adopt some patience, read the guides and try whats best for you.
https://www.videohelp.com/sefy/?id=start1a.html
Convert .mkv and VOB to .avi (xvid)
By Numse in forum Newbie / General discussionsReplies: 2Last Post: 16th Sep 2008, 04:07 -
How Can I convert avi(xvid) to ipod tv out (H.264)?
By felix in forum Video ConversionReplies: 8Last Post: 1st Sep 2008, 11:27 -
convert 2cd Xvid to 1cd xvid Avi
By mehargags in forum Video ConversionReplies: 6Last Post: 14th Apr 2008, 11:55 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 17:51 -
XviD.TG.avi convert to iPod.
By kieran_92 in forum Video ConversionReplies: 7Last Post: 3rd Aug 2007, 06:20
