Hi All,
Im kinda new to this whole tech video world. I just recently bought a capture card for my machine. To be honest I dont know which one I bought. It was fairly cheap- 40 bucks (us dollars) and when I hook up the satalite I dont get any sound. Is there something that I am doing wrong? I am not too sure on what I can do to fix the problem. Any info would help. Thanks!!
Skoobeedu
Hey there . . .
A few more details, like the brand of card, type of chipset (which should be written on the box or the instructions) and the way in which you've connected everything up to your machine, would be really useful bits of information - the fiorum is "flying blind" otherwise . . .
B.===============================
"Don't ask for my specs - click the b*&^dy button . . ."
yea, I guess that would help huh? okay here goes...
Im running a kt400 chipset with gigabyte motherboard running a AMD 2100+ with 1 gb of ram. AVerTV video capture card / yamaha CD+RW / Verbatium DVD+R/RW... Maxtor 160gb HD
I think that I got everything there... Anything that I left out? -
Hey . . .
Sounds good so far - now, how a\exactly are you hooking up your satellite feed to be captured? Is it a case of composite video into the capture card, and audio into the card as well? Or does audio go straight into the "line in" port of your sound card?
the aux cable is put directly into the card. I assume the audio is input as well through the aux cable, but I think that I may be wrong? I think that I need to get AV chords to plug in to the sat receiver.... Yeah???
Yes, I have the same problem. I don't believe the card will pick up the sound from the coaxle cable. You need composite A/V. I guess you could go coaxle and just hook up the sound through composite.
Don't give in to DVD2ONE, that leads to the dark side. -
I think that I need to get the AV cable to the 1/4 inch connector so I can hook it up to the card. I think that I can hook it up to the sound card as well. I guess I will have to run to the radio shack. Thats how they stay in business. I was hoping to aviod running all the chords across the house, the lady is gonna be mad at me
thanks for the info all
Skoobeedu -
How about hooking up the coaxle to a VCR in the room you are in then go out of the vcr in composite to the computer...
USB 2.0 Video Audio capture Card
By jj3502 in forum Capturing and VCRReplies: 0Last Post: 3rd Feb 2010, 05:09 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 03:48 -
PCTV Rave Card - trouble capturing xbox + tv audio
By chocolate_brownie in forum Capturing and VCRReplies: 2Last Post: 24th Jul 2007, 09:38 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
