I'm pretty new to this. I've had good luck, 100%, with Maxell and TDK that I have bought locally. However, they are running over $4 a disk. Is there a difference between these disks and the bulk, same-name, ones on ebay?
I got some bulk, no-names, on ebay, and I'm batting 40% if I fill the disk and 80% if I don't. Either way it just isn't worth it. Why do these disks s***?
Thanks in advance![]()
I tried the cheapest DVD-R Supermediastore had (advertised at this site)
and am batting 100%.
The answer to your question of why? I don't know but stay away from ebay.
Some DVD burners are picky maybe?
P.S. I have a Toshiba burner, most people here are big on Sony or A05, mine works fine. -
I'd go with 1X Ritek (1.59?) or 4X Ritek (1.95)
I have burned well over 600 with only one or two coasters, which were my fault anyway.
Andy
2X TDKs are nice, but they are still in the $3 range. -
Where are you finding the Riteks for 1.59? Canadian, maybe? You can find them all over the place for around 1.20. I usually get mine at Rima, but I'm batting 1.000 so far with them.
Discs with no top-coating will die in time (common problem with CD, as now are many dying fromt he early days). Pay a few pennis more per disc (even a buck more per disc) and get one that has a good coating, and from a good brand.
OptoDiscs are good bulk discs. About $1-$2 eachI'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
Media Player Question
By gazbag in forum Media Center PC / MediaCentersReplies: 1Last Post: 5th Jan 2011, 09:54 -
question re wd hd media player
By julie_152 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Sep 2009, 11:46 -
FAQ didn't answer my question. What's the best DVD-R 9GB media to buy?
By insomnia976 in forum MediaReplies: 7Last Post: 18th Jul 2009, 13:10 -
Which media is best for....(a noob question)
By reinstalled in forum MediaReplies: 5Last Post: 29th Nov 2008, 08:49 -
Question about + or - DVD media
By OzarkBaby in forum Newbie / General discussionsReplies: 7Last Post: 16th Dec 2007, 18:19
