I am new to this dvd copying,so any help would be great.
i am useing smart ripper,dvd2one and copy to dvd,
i am having no problem ripping,and dvd2one works fine but when i go to copy to dvd it goes through the first stage writing to cache file??,and then when the burning starts or formating as it says on the box i get error messages saying "invaild data file " if i leave the error it keeps poping up so my whole scren is covered in this error message?
the dvd files are still on the hard drive in vob files are i can watch them but to get this working would be great,any help please
Gregg
superman
What program are you using to burn ?
If it is Nero, do the following. I have had 100% success.
Close the wizard, CLICK ON FILE, NEW.
From the drop down click on dvd.
Then click on DVD Video and click on new. A window will open up on the left hand side. Click on the folder VIDEO_TS (which is coloured red.
The on the right hand side filer browser find where you stored your vob, ifo & bup files and drag them all to the left hand window.
Then push the burn icon and off you go.
If it is another program you need to have folders VIDEO_TS (THIS ONE HAS ALL YOUR FILES IN IT) & AUDIO_TS (NOTHING IN THIS FOLDER)
The names from the folders must be in capitals.
Hope this help.
dlb. -
i am useing copy2dvd,but have just decided to use nero i will let you know howi get on .thanks guys
superman
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 20:01 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26 -
Help, Problem with Intervideo dvd copy 5 platinum
By heman28 in forum DVD RippingReplies: 2Last Post: 3rd Jan 2008, 21:12 -
Power DVD Copy Problem
By Tel in forum Authoring (DVD)Replies: 3Last Post: 8th Aug 2007, 17:51 -
dvd copy problem
By ht0160 in forum DVD RippingReplies: 10Last Post: 1st Jul 2007, 18:31
