    Apr 2003
    Sydney
    Hiya all
    Please help no matter what i do on the save dvd swimfan r 4 after i play a coiuple of chapters in my superdrive when i go to use dvd backup i get a dvd encryption error on the video_ts file this has happend on 2 copies ant ideas ?
    Cheers
  2. Scratches on the disc maybe?
    Try using OSEx ripper.
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    Agreed
    Scratches or dirt/fingerprints/dust can cause backup errors
    1. try running warm water on the disk shaking any excess water off and wiping with a lint free cloth
    2. If that doesnt help, try a small amout of soap which you can rub on the disk itself with your finger, then rinsing with warm water and shaking/drying
    3. if that doesnt work, rubbing a VERY small amount of toothpaste (paste, not gel) all over the disk followed with water, shaking, drying etc. That may help.
    I would try 1 before 2 before 3.
    IF that doesnt work, you can copy the dvd entirely to your HD (using the OPTION-DRAG) function which will copy the dvd itself to your HD. THen you can use dvd backup on that copied dvd. If it errors on copying then you probably have a disk that just cant be backed up.
    But still try OSeX. Perhaps it can process the backup.
  4. Member Thargok's Avatar
    Nov 2001
    After #3 above I would use a DVD doctor or something else that "grinds" the disk down. Although expect hours of buffering before your DVD can be seen by the computer.
  5. Member galactica's Avatar
    Jan 2003
    Do they actually have something like this!?!?
    Is the data safe? Interesting!
