I am using Power VCR to capture and edit television shows with no problem. Yet, when I go to burn a VCD, the audio is out of sync with the video(like the old kung fu movies). I have checked the output file and it is fine but after that, it is garbage. System is....
Windows 98SE
AMD Athlon 1.2
768 SDram
Nero 5.5.9
I don't know what I am doing wrong. Thanks in advance..
Results 1 to 1 of 1
Kevin H. Bradford
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
