Hi All,
Anybody knows if there's something similar to the pioneer 2x4xALL for LG writers ??
Thx
Results 1 to 11 of 11
__________
d0oM969 -
what is the problem ? I used princo, Ritek and a noname DVDr.. all burn at 2X with my LG.. which media you have problem ?
Oh! well....
Actually, I dont have any problem, since my burner is a Pioneer
But my friend just bought a LG and it seems he cant burn Princo at 2X ....?
So, thats why I asked the question
thx anyways__________
d0oM969 -
humm.. Copy2DVD dont allow me to burn at 2X (same for the pioneer of my friend), but Nero DOES burn Princo disk at 2X, and BTW, I have lot of problem with Princo disk, don't buy any other ! ritek work fine and cost 20$ more for 100 DVDr. not worth the trouble
I use Firmware A108 on my LG -
Well,
I'm kinda noticing by myself that Princo is Cr@p....
I sure wont buy any other...
What dvd do u use ?__________
d0oM969 -
I have the drive for only 1 month.. I didn't used a lot of media
but Ritek G03 are awersome so far.. not a single problem -
Thx.
I didnt try Ritek so far, but it sure seems like they are the best out there.
Gonna try them some day__________
d0oM969 -
I use this drive for 2+mths, came with firmware A105, now has A108.
I had no problem whatsoever with any brand -R blanks (including cheapest princos & riteks, and I believe I tested every brand available in Canada). Im still waiting for my first coaster with this drive (my previous drive sony dru500 made one on first day
So AFAIK there is no -R media compatibility issues here.
The only trouble I have with this drive it doesnt recognise Maxell DVD-RW that actually came with this drive in its box... but it does read/write all other -RW brands I tried with it so far (optodisc, pioneer, orange case sony, even probly same maxell in slightly different case). I thought fmware upgrade will help, but it didn't :/ -
the maxell DVD-RW that came with work in mine. Maybe a bad media. but RW is a bit too slow so I use Princo disk if I have test to make and -RAM for backup.Originally Posted by DereX888
I have no coaster so far too. near 20 burn in 1 month -
I've had problems with the computer locking at exactly 15 seconds into a burn when using Infiniti DVDs and Nero (5.5.10.28). DVD-RWs are ok though.
However, I've since tried CopyToDVD and that's worked fine, even copying at 2x.
Mine came with 107 firmware, upgraded to 108. -
probably a windows ProblemOriginally Posted by alchemistresearch
Everytime I put a DVD-RAM or DVD-RW (or even CD-RW or a Compact flash reader) Windows Reboot.. will need to format
