    May 2002
    England
    I'm trying to change the fourcc code on a AVI file to the Canopus codec CDVC so that I can open it in Virtualdub.
    Virtualdub allows me to open an AVI already captured with a Canopus card. Below is what I see when I open the file with avic.
    FourCC Description Code CDVC
    FourCC Used Codec @
    (Note the square box above appears as a bold bar '|' in the avic field, I cut and pasted from there to the topic window)
    When I open the non Canopus codec AVI I see
    FourCC Description Code dvsd
    FourCC Used Codec ÿÿ ÿ
    So I update the 2 fields above to CDVC, apply and quit. If I then open the file in Virtualdub i get the error message
    'Couldn't locate compressor for format 'dvsd'.
    Opening the file again in avic shows me CDVC in both fields.
    I can open both AVI files in Tmpgenc.
    Can anyone advise please.
    May 2002
    England
    I can use the Canopus DV file converter to convert the AVI and then it loads into Virtualdub. But that takes time and extra disc space for 2 files.
    Any help in getting AVIC to work would be much appreciated.
    May 2002
    England
    The file is AVI type 1. If I convert it to type 2 AVIC then works and I can open it in Virtualdub.
