  1. I'm using DVDShrink and I've tried many times to get full movie. I really only want widescreen and all menus. I can't figue out which file is wide screen? I tried to preview but both files look the same....would widescreen be the larger of the two movie files? HELP!
  2. I used DVD Decrypter and InstantCopy and removed the Full Screen movie. Piece of cake, no problems...
  3. thats great that you had no problems but my question was which file is the widescreen?? the bigger movie file or the smaller one.
  4. Use the preview in DVDShrink and you can tell the difference...
    -=[ JHMac ]=-
    Experience is something you don't get until just after you need it.
  5. The one where things are slimmer than normal, top to bottom, is the widescreen.
    LTA
  6. @JonnySkidmark
    What region are you trying to do?
  7. What region are you trying to do?
    What does that have to do with anything? He has asked a very simple question, that deserves a very simple answer. You guys are just confusing the issue.
    LTA
  8. Originally Posted by Triple_Helix
    Are you flaming me? Read on Triple_Helix...
    LTA
    For your information, it does alot if JonnySkidmark is doing region 1 Van Wilder unrated because there is an awesome working cheat sheet by 2COOL @ Doom9 on bypassing the Aspect Ratio Menu. Don't limit yourself to just this forum! There are valuable information else where too! Now am I still confusing the issue?
