Does anyone know of a good way to make programs such as CCE not use so much of the CPU. I want to do other things on the computer while encoding in the background without it taking forever for me to do my primary task. I don't care if CCE or whatever other task I'm doing in the background takes longer. I'm using Windows XP.
Use Task Manager and lower the CPU priority. Right click on your start menu bar, and select Task Manager. From there, click the Processes tab and look for the running exe of CCE. Right click on the process, and you'll see the pop-up menu where you can set the priority level of the program.
New CPU
By Sckinhunter in forum ComputerReplies: 9Last Post: 13th Apr 2011, 02:10 -
CPU
By HotDamn! in forum ComputerReplies: 7Last Post: 17th Dec 2009, 02:21 -
Is Windows itself a power hog?
By ahhaa in forum ComputerReplies: 5Last Post: 19th Aug 2008, 23:01 -
MacPar deluxe 'CPU' hog in a MacPro?
By rotuts in forum MacReplies: 9Last Post: 19th Oct 2007, 16:49 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 20:33
