    May 2003
    India
    hi all friends,
    I want to convert 250 Video cassates into VCD.
    I want good quality.
    please send proper instructions.
    My PC configuration:
    Celeron 1.2GHz
    256 MB SD RAM
    40 GB HDD
    I have following questions. Better if you answer them pointwise.
    Thanks.
    * What else I need.
    * Can i use TV tuner card to convert?
    * Do i need to upgrade PC ?
    * Upgradation of PC will help me in quality or not?
    * If I need up grade the PC then what shoud be the proper configuration for that ?
    * TV tuner card is better or Capture card is better?
    * Which VCR is bertter to play Video cassates to do all work.
    * cassates are 10-15 years old
    * How can i clean cassates in better way?
    New Member
    Manan
  2. check the guides on your left first
  3. Member Nitemare's Avatar
    Jan 2003
    If you want quality then VCD might not be your best choice. I only use VCD when my source tape is SO bad that it would be a waste to use anything higher.
    SVCD would eliminate a de-interlacing step (depending on capture method). I agree with K2. Check the guides first. The methods used for this are many and varied, making it impossible to answer your questions.
    Besides, it's a slight breach of protocol to ask such an involved question without making any effort to research the information that is already here. I don't say that as flame... just as a helpful tip. You'll find the people on this board friendly and eager to help, provided you've shown evidence that you're willing to help yourself. This is the most newbie-friendly forum I've ever seen... and I should know... I'm barely out of my training pants myself!
    Research the guides and when/if you need advice or clarification on a specific question you'll be surprised at the response you'll get from this board. We're not refusing to answer because you haven't looked for yourself. Honestly. Once you read the guides you'll realize that the questions you've asked are too vague to really answer effectively.
    A comparable question would be "The road I'm driving on forks into five different directions... which one should I take?"
    Some pointers to get you started... check out your DVD player. Will it play VCD, SVCD? If yes/no... research the guides and software... there are some hardware reviews as well... capture devices, DVD players and whatnot. Focus on your "final goal" (eventual DVD conversion?) and plan according to that. Also... quality is subjective and gets argued on here all the time. You'll be told over and over to make some discs and decide for yourself... it really IS the only way to do it.
    Welcome to the board!
    Nitemare
    Even a broken clock is right twice a day.
    May 2003
    India
    OK first i will see all that
