im in the middle of creating a svcd with Ulead DVD MovieFactory 2.
i wanted to create a slide show before the first chapter kinda like
a preview of the first scene.the quality of the video is actually pretty
good.im using windvd to capture the pictures for the slide show.but
they dont seem to come out nearly as good as as what the video
looks like.can someone suggest what i should be using to capture
the images from the video for the slide show.or am i pretty much
stuck with the quality i get from windvd.
thanks
armand
Are you capturing the pix off the source AVI or off the Mpeg-2 SVCD?
The quality will always be better from the AVI because of little or no compression. you should be able to open the AVI in Widvd to get the pix. If not, then try Virtualdub, TEMPGenc ect. Otherwise use scanned or imported pictures if your not happy with quality.
Good luck!Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
yeah im getting the pictures from the mpeg.i just think the quality of the picture is not nearly as good as the mpeg.but i guess ill just use the
ones im getting now.
thanks
armand -
Another option is to use VirtualDub (the MPEG2 version).
Open the video in Vdub and apply whatever filters you need to clean up and enhance the image (including resize if that helps), then pick the frame you want and select 'Video' -> 'Copy output frame to clipboard'.
You can get some pretty good frame captures this way.
Photo Slide Show in AVCHD
By chrisnewton in forum Authoring (Blu-ray)Replies: 8Last Post: 23rd Apr 2011, 03:40 -
Making an interesting start to a slide show
By avz10 in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2010, 23:57 -
Memories on TV Photo Slide Show program, help??? Please.
By vanc in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2008, 12:34 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 07:27 -
Adding slide show to a movied DVD
By leungf in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 08:55
