I'm a TOTAL newbie, and trying to get my head around this.
Is this right:
1. use DVDdecrypter to rip the DVD (to VOB files?),
2. use Headache to encode the sound from the Vob files (at 48KHz?),
3. use TMPeg to encode the video from the Vob files (to MPEG2?),
4. use ddMPEG to mux the resulting audio and video files to one file, and
5 . use Nero to burn the SVCD (non standard compliant mode?).
Or you could download Eazy Vcd from the tools menu and that will do the lot for you.
You can also use DVDx 2.1 (Latest Version) (DVDxCopy) its able to re-encode dvds to vcd, svcd and even avi. A very simple programme to use for newbies, and worth checking out, just look in the tools section and im sure you'll find a link there.
The guide is also available in guides section, hope that helps.
kas187 -
Yes, I already saw EasyVCD and DVDx (v.2.2, I think) on several download pages.
From what I understood by reading thru the forums here and elsewhere is that using individual programs (doing things "by hand") gets a better result? -
Actually it's called bbMPEG, not ddMPEG
You should probably check out the guides some more, or maybe get DVD2SVCD at www.dvd2svcd.org.
I prefer to use VCDEasy to master/author the SVCD then burn it, rather than using Nero. My DVD player has a "time search" function (as in, I want to go to minute 15, I type in 1-5-0-0) and SVCD's burned with nero (for some reason) lose this capability.
Also I prefer to do things manually, because (in my opinion) DVDx 2.2 (or 2.2a or whatever the latest version is) is very slow...and you can't turn the previews off (grr) which would probably speed up encoding immensely. -
ive only used DVDx once, and it did quite a while to convert a dvd, actually it was about 8 hours, an overnight job, but i was pleased with the quality of the video,
good luck i deciding may the force with you,
first steps in simple editing: from vro to dvd?
By lightningbit in forum Newbie / General discussionsReplies: 7Last Post: 17th Aug 2009, 12:56 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 03:01 -
Steps and Tips: How to Convert DVD to iPhone on Mac
By guns1inger in forum User guidesReplies: 1Last Post: 23rd Aug 2007, 23:46 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 16:09 -
Which steps should I use?
By Belfour in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2007, 10:33
